nautica_t wrote:i'm going a rear diff swap.i have a 91 parts car. and i've read that you can do a straight rear diff swap, and i've got all the bolts off and its already hanging a bit low, but its being held up by a floor jack, but the rear diff is still stuck to the rear axles. just having trouble removing them.
OHHHHH. I get what you are saying.
The axles have these nubs on the ends of them that fit into the halfshafts on the differential. Simply pull the axles away from the halfshafts (They are compressible and flexible), and get the nubs out of the halfshafts and out of the way. From there you can lower the diff all the way out of the car.
No hammer required for this.
