HELP! vibrating sound when turning at certain angle
freelancer
i got a 95. when the car is turning right at a certain angle the front right makes a vibrating sound, its louder when im on high speed, but once pass that angle the sound goes away. i dont know how exactly to describe thaat sound, but virbrating is probably the closest sound, also i can feel my steering wheel is virbrating very slightly.
thank you for you help
Structure240sx
check tire rods and ends, this would make the most sense
check the TC rod bushings. they connect the front control arm to the frame. they are often worn out when still stock
freelancer
thank you, but what if the vibrating sounds basically start whenever i turn towards right, and only makes louder noise at that angle and high speed, is there any other possibility?
thank you
