Oh hey dude, good move signing up to NICO, this is the most informative place on the net for VH V8 engine information.
The VH engine is front sumped, like an RB, and should have fine clearance over your crossmember and steering rack. If it doesn't, swap out the crossmember for an RB crossmember & you'll be fine... my VH41 sits perfectly in my engine bay, with the sump between the sway bar and the crossmember.
The 45 should fit fine judging by what I've seen of other VH45 into silvia transplants.
You need to pull the front covers off your motor to see if the timing chain guides are metal or plastic... you can buy the metal replacement ones brand new through Jim Wright Nissan, as they revised them. It's advisable you do this if you find them to be plastic.
Since yours has the siamesed intake ports, the heads won't flow quite as well as the later model VH45 or the VH41... it won't be as noticable since you plan to boost the motor, and may result in lower down torque for you... ideal if you want to drift it, however it'll limit your peak high RPM power. Not a big deal, you could still easily get 600hp+
Don't replace your injectors with subaru ones, go for SR20DET injectors... though if you want 600HP, definitely upgrade to NISMO 500cc+ injectors... factory 370ccs will only take about 500HP absolute max, and you always want a bit more leeway than maxing out injectors.
Your brake booster is going to be too big and interfere with the right head/rocker cover, get a smaller one. Certain Mitsubishi ones share the same pattern on their mounting studs, but the studs are too short. I'm using a mitsubishi colt brake booster (it's only single diaphragm, might need to find a dual one if it doesn't work too well), but it's tiny diameter and it fits.
As for the stud problem, your brake pedal is bolted to a plate/spacer, that spaces it around 20mm off the wirewall. The thread of the booster won't stick out far enough through this spacer in the footwell, so the plate and everything needs removing so it's just firewall with holes... and then the thread extenders are wound on to the brake booster studs, and the shoulders of the thread extenders are the same length dimension as the original pedal spacer plate was from the firewall.
Biggest clearance problem is clutch master cylinder. Find one that hardly sticks out, the guts of which are on the inside of the firewall... then chop and change the back of the rocker cover for clearance, and you should be ok.
As for single turbo, I'd advise twinturbo since it'd be less of a fabrication nightmare than trying to plumb two exhaust systems into one turbo.
Here on NICO, we've established that the VH V8 engine internals should be strong enough to push up to about 800-1000hp (with very good tuning to ensure there's no failure), at 600HP you'll be fine !
The link G2 will be a nice investment if you're running a MAP sensor, but if you're sticking with the factory MAF, then don't even bother. Socket your ECU, and program your own EEPROM... it's actually pretty easy, I can go over it with you if you're interested.
Hope this helps !
gdz1la wrote:i brougth a vh45 for a s15 it will be track only similar or same as s14 and s13 engine bays.. is it to big? i measure and it seams to of fit between rails but not sure about rack etc clearance
it has the simeise ports (36 intake ports out iof heads)i havent checked the guides, how do i tell if 94 or above?
if its got **** guides i might trade up for a 41, will this be easier to fit?
i removed the inj and damaged them, i didnt relise already 380cc, i now am insatlling ej20 subaru 380cc as the originals are damaged..
its rhd (New zealand)will the brake clutch cyl the steering rack etc clear? its turbo so ther manifolds will be floing forward, what other clearance issures are there?
the chassis has frontal damage so will be spaced framed froward of strut towers.. so alt and ps pump clearance not a issue
will be running z32 5speed and muiltiplate, link g2 engine managment (8channel fuel and ign) greddy t78 33d or t88 34d single turbo ill be aiming for 600hp (inj max out) will this be all good? i have run std rb30e bottom ends to that so 75hp/rod vs 100hp smaller rod should be a walk in the park..
im also missing 1 of the 2 vvt solinoids, can i simplt cap them or will it make more torque switching them if turbo? any one wana sell me one?
