Help/Verification: SAFC and AVC-R Combo Install
ace0073
Car: 1969 datsun 510
ok so, i have to start with saying that i searched and i have to say that i received different info....use this diagram, use that diagram, blah blah blah. Needless to say, I was confused. Here is what i came up with and i am looking for anyone to verify or correct this info before i hook up these wires and start an electrical fire in my vehicle:) Here we go.....
I purchased an avc-r/safc ii in a deal both used, without manuals. came on the forum, searched, got confused. checked apexi site, searched, tried to decipher the japanese characters, got a little info that (in some cases) did not line-up with forum info, got confused. Finally, between the two came up with the following.
Necessary info:95 ka24de-tOBD I75lbs injectorst3/t4cobra MAFJWT ECU
Using Diagram N-1:http://www.apexi-usa.com/pdfWiring/5.pdf
Common Wires:
SAFC-II-----AVC-R-----ECU
red-----red-----powergreen-----purple-----RPMbrown-----green-----Ground (close to ECU)black-----black-----Ground (further from ECU)
Additional SAFC-II Wiresyellow-----Air Flow Outputwhite-----Air Flow Input
Additional AVC-R Wiresgray-----Throttle SignalWhite-----Speed Signal <--- ??WHERE DO I FIND THIS??
Modified by ace0073 at 7:37 AM 6/21/2007
TheOne
Car: 93 240sx FB
http://www.innovatemotorsports...X.php
pin 26
the safc 2 has a knock sensor wire also.http://www.ka-t.org/forums/viewtopic.php?t=8089
ace0073
thank u very much....im on it!
Modified by ace0073 at 4:02 PM 6/22/2007
