Help! VDC, ABS, and slip
rdiver
Car: 2003 Infiniti M45
Hello all, I am in a new member. I hope you guys and girls can help me out with this!!
I recently purchased a 03 M45 Infiniti. I replaced all four calipers, now for the life of me, I cannot get the VDC, ABS, and Slip light to go out. Please help!
Thanx Rdivers
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Is the brake fluid low? If not, get the ABS codes read, you may have damaged a wheel sensor.
Ilya
Yep, check your brake fluid. This should have come up in many searches on Google so it's a shame you replaced all of the calipers but I guess now you won't need to do it anymore.
rdiver
Thank you for the help, flulid is good, codes are saying the abs pump and the several relays are bad. Can anyone tell me where these componets are located. Oh yeah, the wheels sensors are are all intact.
VStar650CL
Technical Expert
The pump is inside the ABS and so are the relay drivers. The two main relays are generally external but the ABS can't drive them without power. Check your fusible links, there's a good chance you blew the main pump supply. Check the ground wire also, all Nissan/Infiniti ABS's have their own dedicated ground wire not shared with any other system.
JOHNQ
Car: 99Qt
02 Q
03 M
Had this problem with my y34. Since all abs sensors looked intact I replaced the pump but still had the same codes. I then took off each sensor and found a hairline crack on the outer edge of one of the fronts. Replaced it with a used one I got from an f50 q45 and no more warning lights. :mike
