504 350z »
https://forums.nicoclub.com/504-350z-u76705.html
Tue Nov 06, 2007 9:19 am
go to crutchfield.com, type in your car and they will list what fits the car exactly. as far stock stereo...jl audio makes a item called Clean Sweep sound processor...... "You can keep the look and functionality of your factory stereo, and still get outstanding audiophile sound with JL Audio's CleanSweep sound processor. It connects to your factory stereo's speaker lines and cleans up the stereo's output by sweeping away any processing from the stereo that could diminish the sound quality.
Many factory stereos use built-in equalization designed to make cheap factory speakers sound better, but this dressed-up signal can prevent aftermarket speakers from living up to their potential. The CleanSweep uses a 32-bit digital signal processor to remove the factory adjustments, then sends your external amplifiers a perfectly clean signal."....hope this helps....
