HELP!! URGENT!! Head Removal
240nismo
Car: Master of bation
Ok so i have the lower plenum of the intake manifold loose on the front and tied up in the back...the headers are completely off, and the head is loose from the top of the block... Why is the head only moving a little, but won't come out! i wanna get the head to the machining factory tomarrow (monday 21) morning! thanks!:help
PalmerWMD
Car: 2004 350Z
Moved to Online Mechanic from 240SX.
F
Nismo_Freak
Car: 89 Nissan 240SX
If I was at work I could give you an exploded diagram of the KA head. :(
NISTECH
10mm bolt located at the front of the head bolting it to the front cover may also have one at the rear. the bolts are outside the valve area and are only about an inch in length. near the base of the head toward the intake side of the head. like the 2 in the front.
240nismo
i got the 10mm bolts in the front, there was actually 3. but the only ones i can find on the back are on that brass looking bracket that holds the nest of wires along the firewall
NISTECH
is there one on the exhaust side in the rear?cam sprokets off i assume? is the entire intake seperated from the head?
240nismo
its ok, i managed to squeek the old head gasket out and put a new one in... but in my chiltons manual it has steps (a, b, c, d, e) for tightening the head bolts... but all i have is:"a. Torque all bolts to 22ft. lbs. b. Torque all bolts to 58 ft. lbs." then its the bottome of the page (pg 3-46) then on the next page (pg3-47) it starts out saying "gaskets. Refer to the Exhaust Manifold Removal and Installation procedures." so steps c-e are missing, does anybody know the ft. lbs. the head bolts should be tightened to?
DAEDALUS
Car: 1990 Infiniti Q45
I can't answer the torque question, except to say that usually you torque them up, then back down, and back up again in some weird sequence designed to minimize residual stresses in the head. I'm quite concerned about sliding the head gasket in there without a good inspection/cleaning. Anyone else care to comment? The surfaces should be FLAT and CLEAN. Without this step, I believe you'll be at risk of a premature failure.
240nismo
oh no i cleaned the head and scraped all the grime off, and checked to see if the head was warped at all...i found the installation sequence:Tighten all bolts to 22ft lbstighten all bolts to 59 ft lbsloosen all bolts in sequence completelytighten all bolts in sequence to 18-25 ft lbstighten all bolts in sequence to 55-62 ft lbs
thanks for your input guys! hopefully i'll be running by tomarrow afternoon!
