ibjman wrote:Thank you for that!!!
Since I have 3.88 now I think even 3.5 might not be a huge change. I would probably opt for 3.3 if I could find a good set already installed in the pumpkin.
Remembering of coarse....that I have an automatic with all the advantages of a torque converter....so I'm thinking that starting out from a stop would not be such a noticable issue.
Does anyone have opinions on which models I should look around for to locate a 3.3?
As for the H190 configuration.....I understand that H190A's had a bigger pinion bearing. I'm hoping that the one that I have in the 86 now is an A.
Although I have verified that my actual ratio is the correct original 3.88......the tell tale yellow paint markings on the outside rear of the housing indicate that it's a junkyard used unit....so someone before me has already replaced it at some time. Maybe it's an A.....maybe not.
I really want to make a fast trip to Los Angeles soon....so I'd really like to find one.
No one else has yet piped up yet offering to sell me one.
ibjman wrote:Thank you for all the good answers.
I'm reasonably sure it's an H190 since it has a removeable 3rd member. I not sure if its an H190A, however but for my situation it really has no bearing.
It does not have the mileage option. It has an H38 and a carburated Z24.
The only question now is trying to assemble a list of possable vehicles to look for to find a 3.3.
Am I to understand that you are telling me that the only vehicle made with the 3.3 was the 720 pickup with the 2.0 engine.
I read somewhere that some 200xs may haxe had at least a similar high gear option???
I continue to remain hopeful that some member here on the forum will have what I need to sell me.
ibjman wrote:Thanks to all for the help on this issue.
I was able to locate a 3.364 at an auto parts dismantler in the Midwest. $125 + $38 to ship it here.
Kind of pricey for my pocket but the only other 2 that came back on the online parts locator were $150 +.... so maybe I did ok? Now....just hoping it's a good one that doesn't whine like crazy or have a growling bearing in it!
I guess there's little to lose by just flopping it in, filling it with 85W90 synthetic and givin it a spin down the freeway!
By my calculations changing the old 3.889 to a 3.364 will give me a 14% change. Wish me luck!!!!
Regards, Ibjman
ibjman wrote:Yes, I agree, 1/8" freeplay (backlash) would be a great deal more than acceptable especially if the post above is referring to an approx. at the pinion flange as I might guess.
Once the unit arrives I'll do my best to check it out before putting it in.
I would hope the backlash measured at a ring gear tooth would not be much more than .012"....certainly not. More than .016"?
And....one can tell very little about the condition of the pinion bearings untill it's installed and running, assuming of coarse that there's no side to side play at the flange and it doesn't obviously growl while turning by hand. I seriously doubt if it will have any preload torque left.
I might even consider tightening the pinion flange nut a very "wee" bit to add a tiny amount of crush to the collapsable sleeve within, but most likely not as that can be way overdone much too easily.
So, I'll check the backlash and run a tooth pattern on it and if it's anywhere near "good", I'll flop it in & give it a whirl. If I find a bad bearing, I'll just replace them all and then try to set it up as close to "correct" as I can.
Although I would prefer for it to be totally silent like the one installed now, I would not be too concerned about a light whine, assuming I had the knowledge that it was well put together and wouldn't be likely to explode a long way from home.
News at 11........
Regards, ibj....
ibjman wrote:The Junkyard unit arrived via UPS today.
The markings on the unit from the dismantler indicate that it is a 3.364 and I checked that out as true.
I'm thinking that I may have come out ok on this one.
I measured the ring gear backlash at the outer edge and the unit appears "like new" with only .005" lash.
Next, I counted the axle splines found in the planetary pinion axle gears and I came up with 29.
Since I don't have my truck apart yet I don't know what spline count my axles are.
Last question is: Since it's out of an 83, can we assume it's an H190 rather than a later H190A? Is there any way to tell without disassembling the pinion bearings???
I'll post again when mine is out tomorrow. In the meantime I'll be happy to hear your comments.
OBTW: my truck is never loaded it's just a daily driver with a 2.4 and automatic. I may eventually use it to transport a motorcycle once or twice.....but that's it......so I don't anticipate any rear end probs. within my foreseeable future.
I'm almost 69 years now so not that many miles left in me.
Regards, Ibj...
ibjman wrote:Thank you all for all the great posts about this axle issue. I installed it today and it all went off perfectly without a hitch. Preliminaey road test indicated that it works great with no abnormal noises.
In a couple of days, I'll get a longer road test while running a GPS to get an idea of how much the speedo needs adjusting. It was about 3% fast originally as is about standard for most factory stock cars....I'm guessing its about 8 - 10% slow now. Hopefully, there's a transmission speedo driven gear available to correct it.
Speaking about the transmission, I don't see many posts about automatics since a lot of "car" people prefer 4 or 5 speeds.
My newest issue is that the trans appears to make the 1 - 2 upshift way early.....changing to second very soon after departing from a stop...while the 2-3 shift appears normally.
I'll be looking more deeply into the exact forces that come into play that time the shift point....something that affects only the 1-2 upshift.......perhaps there's a spring in the 1-2 shift valve in the valve body that can be changed.
I expect I'll have to spend some time learning about the theory of operation on this tranamission before I can see what can be done.
Of coarse there's nothing in the aftemarket service manuals about the internals of the AT.
Wish me luck.
Thx, ibj...
