Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Mon Mar 14, 2005 8:15 pm
I did not do the head removal, I bought the car w/o the head on it, then I decided to overhaul the motor. But a friend of mine took the head off before I met him, and bought it from the friend he did the work for (odd how fate works, isn't it?) He said he checked the head and block with a straight edge and a flash light, and nothing showed up. He did this because the guy I bought the car from sold it, this is why: He was on the highway doing 90MPH in 4th, went for 5th, hit third. He said the car would not run right, when he got it home and shut it off, he could not get it to start. So he thought it was the head gasket (Yes, I know), I thought it would be a bent distributor shaft. So I got the car with no head on it. We pulled the motor and did a standard re-ring, with some hotter cams. 4K, a whole hella lot of bolt ons, and a few months later (I took my time, have an FR Corolla, too). Anyway, I am no stranger to cars, and I can only assume that I either have a warped/cracked head (which I did not notice when I went over it, but who does?), a broken head gasket (the dowel in the block was sheared off, so it could also be misaligned), I hooked up the coolant line to the AAC (would that pump air into the coolant, isn't that what it does? Pump air I mean.) Or since it has been sitting so long, air is just working it's way out of the block and heating system, I will be running a compression test on St. Patrick's day, then moving to celebration (Irish boy right here!) Also, I will be filling the filter, and taking the sender out, and using a hand syphon pump to prime the pump, who thinks that will work? Some ideas, later on I will be supercharging this car, so any info would be great.
