HELP! Turns over perfectly but won't start! 280K, runs perfectly, what could it be?
Bullseyed
Car: music, esp. guitar
HELP! Turns over perfectly but won't start! 280K, runs perfectly, what could it be?'89, ran good at lunch, after work I hop in, won't start. Checked wires, all that looks good, could it be fuel pump? timing chain?
NISTECH
try holding the throttle to the floor while cranking see if it trieds to fire up. it might just be flooded.
Bullseyed
nope. Electricals are all fine, theres spark and such....
NISTECH
do you have fuel pressure? if so are the injectors pulsing[ a cheap noid light will work,see sticky on "How and where to post" info on light] If you have spark and its not flodded one of those 2 things is gonna be your problem.
Bullseyed
welp, apparently there was a leak in the back, the wiring to the fuel pump basically rotted away......
