HELP!!! TURN SIGNALS PLEASE HELP!!!
infinitiqx4x4x4
I really need to know which fuse is the turn signals. I am really worried i'm going to get pulled over. PLZ HELP IF YOU HAVE ANY IDEA.On a side note my power steering is squealing like no other. I have made sure the fluid is full multiple times. What could this beIts a 1998 Infiniti QX4if you could help you would be so awesome
gwhunt23
Car: 99.5 QX4
Try your hazards. If they work, the problem is not the fuse but rather is some break in the wiring on or near the turn signal stalk. This seems to be a common issue on early model QX4s.
Good luck
