dfwdrifter »
https://forums.nicoclub.com/dfwdrifter-u26791.html
Mon Sep 19, 2005 7:45 am
thanks 4 help, yes i checked my fuses there good. I also went and bought a turn signal flasher and that was not the problem either...My bulbs are good too. My day time running lights come on, hazardous flasher works too... My turn signals dont work now... This is all because of a turn signal happened 2 get shattered in front..Neither my front nor rear turn signals work, but my hazardous does and my combination flasher works. I'm starting to think maybe i burned out the signal switch on the steering column, but it think that would b impossible from a shattered bulb..I think my fuses should've jus burned out instead of a turn signal switch, but there good....maybe it's not my signal switch..lol...but i'ma over look my wiring.
rob
