help turbo wont fit (dam pipes)
b-13det
Car: b-13 SER
cant fit turbo in; soo what can i do with these pipes?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
1. needs to be setup as a "catch can" for the oil that bypasses through valve cover.
2. Was your EGR. You will need to buy an egr block off plate so you can remove that out of the way completely.
3. you are right....
here is a pic of #1 on a sr20det
pic on a sr20 de-t setup
in the second pic, some run the filter you see pictured, but it may cause idle issues. on the stock sr20det setup, it is routed back into the intake pipe. you will have to bend the one in the way of the turbo manifold. just enough to allow it to fit.
