Help! Tuning Problem - Mappers pls CA18DET-EManage Ultimate
Spawn_CA18
Car: 1993 EDM Nissan 200SX S13 CA18DET & 1995 EDM Honda Civic Crx Del Sol EG2 B16A2
hi there all ,
i have a problem about mapping my CA18det.
here is the situation
Specs:
stock injectors
stock turbo
Z32 Maf
Fmic Intercooler 9Lt
Greddy E-Manage Ultimate piggyback
with this values , my idle AFR is set to 14.5-15.5
BUT. when i try to move the car with %10-16 throttle , AFR is goes all the way to the poor level , in aem afr gauge its red level and --- value . the car does not move , stops at 1500 rpm or so.when this happens it does not matter if i pressed down pedal to the metal . i have to release gas and press harder like %30 . when i do it, car moves normally with upper rpm's surely .
sound like misfiring but it isnt
when im changing gears at low rpms and press gas pedal like %10-15 throttle still same situation . car goes poor and and dont move.
but if rpm is like 2000-2500 , throttle is does not matter . it moves with %10-15 throttle.
i cant solve this problem . so please help me . im going nuts.
Map values:
by the way , sorry about my terrible english.
thanks
Buddyworm
Have you tried lowering your pulswidths in the region just off idle?
