HELP! TT sputter and backfire issues. please
jt1237
Car: 1990 Nissan 300zx TT
Hello,
I have a 1990 300zx TT that I got probably a month and a half ago after selling my 350z. Now this car was sitting for a few years so it required a decent amount of work and I am still trying to get this car to 100%. Now I am currently having an issue with my engine.. It has around 100k on it(swapped out to jdmtt-car was originally a tt) and before it sat the timing belt was changed probably 1-10k miles beforehand.
The car drops and rises and drops in rpms when i first start it. It takes a few seconds for it to even out and it smells of gas when it's started.. There are no noticeable gas leaks. The engine also sputters or putters whatever you want to call it. It go bumbumbumbubmubmbumbumbubmubmubmbumb like it has a huge cam in it. (The car is obviously missing) And it also backfires after I let off of full throttle at certain rpms in certain gears or after I'm 3+psi of boost. So the a/f ratio is probably wacked. I am wondering what might fix this problem so my car can regain full power. It has clogged cats (which are being removed this week) and my passanger side o2 threw a code once and failed the ecu test. I am replacing that tomorrow morning(hopefully fixes it) Now this is what I have replaced so far. Also cleaning the MAF soon.
-Spark Plugs
-Fuel filter
-Fuel PUMP
-Starter(blew out on me)
-Throttle position sensor(was all corroded)
Also has 15lbs boost jets already in it when i got it.
Could it be my CAS? Would that fix my issue? I am not sure if it is an injector problem or not.
PLEASE HELP!
Any advice is appreciated, thank you so much! (Can provide video if needed)
amiry36
Ohm test the injectors. Check for coroded connections. You have to fix the misfire first. And also fix the gutted cats. If cam angle sensor was bad, your rpm's would be limited to only 5k and your rpm needle would go crazy jumping from 1k to 3k. Also does ecu throw any codes other than the o2 sensor?
clazman
Car: 1990 300zx TT 5 speed MT
Also try the bypass test for the knock sensor. You'll need a 1 Megaohm resister. Or 2 500 Ohm and wire them together.
Just dealt with a faulty knock sensor in my car yesterday. ECU was showing faulty Knock Sensor. The sensor wasn't completely dead, so the ecu was getting weird readings and kept trying to fix the "knock" so it kept cutting the spark, with the result being unburnt fuel smoke, rpm hunting and eventually stalling out.
