Cleveland180 »
https://forums.nicoclub.com/cleveland180-u25891.html
Mon Mar 22, 2010 9:04 am
Well I made the trek home to work on my car some this weekend and here is what I got.I pulled the codes and I got Maf circuita/t controlTPS circuit
So, I pulled the IACV and AACV and cleaned them up, then adjusted the idle, and replaced the gaskets. I also removed the TPS to see if anything on there needed to be clean, but all the contacts looked nice and clean, and everything moved smoothly. I started up my engine with all the sensors pugged in, and it ran exactly the same, I unplugged the sensors one by one, and each produced an audible change in the way the engine ran. I assume they are working.As for the maf wiring, I checked my wiring and I am hoping for some conformation on my wiring.blk/wht = powerblack= groundother black= signal ground white= sensor feedback. I do have a Turbo XS d-tec wired in and I can see that my maf load is at 3.5V when it is running at the crappy idle. The D-tec also draws from the TPS and that does not seem to be working. I assume the the tps would still send a signal when the key is turned but the engine is off, however the signal is not changing when i open and close the throttle. But, like I said, when the tps is unplugged the engine is definitely affected. I also did a boost leak test and found that two small caps I had put on cracked and were leaking, so I replugged them, but they didn't fix anything. I tested my fpr's and they are both working. I read in another topic that our cars are very picky when it comes to any oddities in the signals, so I made sure that all my solders were good, and they are. Any Ideas? I am currently thinking about buying another motor set, and just switching everything over, but I really don't wanna do that since it's a rb20 and i feel like it would be a shame for me to be hogging all of them, not to mention that would be another $1300 on an engine and times are tough in this great country.Any help would be appreciated.
