thanks guys, couple more questions180fan, could you post a pic of the two alterations you made? I think I get it, but I'd like some visual confirmation as well. Also, what do these changes actually do?
I don't think I've made it as far as you guys are pointing me though :-(.I have the 4 sensors that connect directly to the transmission, as well as the VSS, all hooked up to their corresponding plugs. Those all connect "under" the car. However, when I get into the engine bay, there's a bunch of other plugs and I get lost. I've sorted out several of them, but by my impression I should leave the stock wires in place (starter, etc) for many of them, so should I just cut these from the manual transmission harness? Essentially I've got signals coming from the transmission through the harness, but I've got nowhere for them to go because I don't know what to plug into where...On the fuse box, there are three connectors that are attached, which is where the auto transmission hooked up. Do I need any of these? A picture of where you guys have put your plugs and such would be really helpful I think.I'm REALLY confused. Thanks for the help guys, just bear with me a little bit longer please
