HELP!! tranmission top bult...
skylet414
Car: 1993 Nissan 240sx
im tryin to take off my tranmission, its a manual.. its a 93 240sx.. so i like took off all the bolts except the top one.. its the one behind the engine.. so like im stuck. so please leave some suggestion or how to take it off, n if theres a post for it please put it down. any help would be wonderfull. thanks in head for helping..
theboz
Car: 1990 240SX coupe SR20DET, 1995 S14 SE DD, 1995 Civic Hatch, 1993 GMC 2500HD, 2004 Suzuki XL7
You need about 3 feet worth of extensions a swivel and short socket. It helps to have someone with small hands guide the socket onto the bolt head. Also if you unbolt the transmission crossmember, with the transmission supported on jacks, and lower the tail a bit it makes snaking the extensioins with swivel and socket on a bit easier. This is how I have done it. on the S14 I just left the transmission connected and I could snake it in. Sometimes you can get to it with a ratcheting wrench from the side but is a pain in the a$$.
