redneckincanadahttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113HELP! Trailer hitch fuse for '02 Pathfinder - Where??Fri May 06, 2016 8:46 am
Postby
redneckincanada »
https://forums.nicoclub.com/redneckincanada-u241590.htmlFri May 06, 2016 8:46 am
Where is it??
I can find this fuse anywhere. I googled the crap outta this and still nothing.
Tried the "Tail" 10A fuse located on the pass. side box next to the battery, and it is fine.
I've had this truck for years and never had this problem with my trailer lights not working.
I know it's not the trailer because I hooked it up to another truck. I'm assuming there is a fuse blown somewhere.
Postby
Hawairish »
https://forums.nicoclub.com/hawairish-u243869.htmlFri May 06, 2016 8:43 pm
Is this an OEM harness or something? None of the aftermarket harnesses I've installed had fuses...they just tapped into the brake light wiring at the connectors.
What exactly isn't working? If none of the lights work, it's probably a bad ground. The turn signals and brake lights have their own leads, so you'd only see 1 or so not work. Do your trucks lights work ok?
Postby
EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.htmlSat May 07, 2016 8:31 am
Yeah, no dedicated trailer fuse on my 02 qx4 either. What I can tell you is that I keep spare headlamp fuses because the vehicle likes to blow those most times as I hook up a trailer harness.
Postby
GrubyFngaz »
https://forums.nicoclub.com/grubyfngaz-u183.htmlMon May 09, 2016 8:25 am
I can again confirm my aftermarket trailer wiring does not have a fuse, maybe just need to check the connections/ground, somewhere around the taillights if I had to guess (mine are pig tailed into the drivers side brake lights)
