Some say the rb25det will essentially bolt in to a s13 and s14(espesially if you have someone make custom A/C and power steering lines and convert your harness for you) - Some say it will keep your car off the road for 6 mos.
Some say 550hp is possible on stock internals and to get 400hp, one would just need a good clutch, FMIC, better turbo and to turn up the boost. - some say there are more parts you need to buy.
some say it'll irrevocably hurt your handling, others say you can get around it with a good suspension set up.
some say that the relitive cost for 400hp on a rb and sr20det is the same because of the need for bigger or forged almost everything in the sr - and some say the RB will still cost quite a bit more.
To take the variables down to a minimum just say...
- Power goal - low 12's (12.0-12.3) in full street trim with streetable but drag-biased tires.- S14 chassis- 70% street 15% autocross/track 10% drag use and 5% drift- coilovers with the proper spring rate and proper tuning for each set up.
Thanks in advance.
