HELP TIMING!!
Kuno3x16
Car: CARS
problem...SR20DET s13
i put on a metal head gasket... and it ran fine but started leaking a little oil around the head gasket area...i rebolted head...i marked on the chain and cams to where they originally were and put them back in...i put the chain and cams back in their original spot and moved the little dots on the cams at 12 and 10 o'clock and aligned my Crank Angle Sensor according to phase2motorsports...now it'll crank but won't start...
any ideas?? =\...
quiksilvia
Car: 95 s14 se
hows ur battery? and try rotating the cas.
Kuno3x16
Car: CARS
battery is fine i just got a brand spankin new one cause my old one died =\...
and which way do i move it to?cause the CAS.. the Marking on the CAS is suppose to be aligned with one of the 2 dots right??... the dot on the left...i tried realigning it like... 2-3 times hehe...just to be sure it wasn't the alignment..
