Conspirator05 »
https://forums.nicoclub.com/conspirator05-u133568.html
Thu May 28, 2009 1:11 pm
Alright so, I just bought an '85 turbo a few weeks ago and we're doing the whole timing belt shin-dig. However, we can't get the timing sprocket off. We've wedged screw-drivers between the sprocket and plate, bent the plate up a bit (it's ok we're replacing it); seriously just can't get it off. A mechanic suggested getting a torch and heating it up slightly to get it to expand, so we might try that tomorrow. Also there was a suggestion of drilling holes in order to get a pulley to get it off, but that means buying a new sprocket.
In doing this job we found out that there was an after-market harmonic balancer on the crank, and it looks like whoever put it on torched it on and messed up the alignment on the pulley where the key slides through, so it seems the sprocket could've been wedged in whenever that was done.
ALSO, I'm curious... we had issues getting the balancer off and ended up scratching it a bit on the sides. We figure we can sand it down so that it doesn't mess up the belt. Does anyone oppose?
This is what it looks like from whoever put this on...
Looks like they drilled the crap out of it. :-\
