dickie »
https://forums.nicoclub.com/dickie-u32299.html
Mon Sep 26, 2005 7:20 am
heres a ****ing update for you:
well even though i was using two guides and the nissan fsm im pretty sure i effed up my car. i had it towed to the shop this morning because it refuses to start. upon checking the position of the crank pulley to the cams and distributor, my dist. is in the right position when the cam lobes show tdc. but even before i started, the mark on the crank pulley was way off from tdc... could this be the p.o.'s work?
anyways i went from having a running (albeit in need of a little work) car to a pretty looking car-shaped statue in front of my house to sending it off for the professionals to rape me because i thought i could do it myself.
heres some reflections on the job:
everything came apart great, within the first hour the valve cover was cleaned and drying and i had the front timing cover and distributor off and was working on my guides.
i must attribute the success i experienced during the removal of the guides to the wealth of information and the fsm i had read 10 times before attempting and twice during the job. new gaskets, rtv, everything goes back together like a dream. i take a break, come back out and give it a second look, and decide to start the car. it acts like it wants to turn over, but it wont go. so im confused now. i recheck the spark plugs, the firing order, etc. all good. so i think oh **** maybe the dist. is off by like 1 tooth or something, even though i marked it and installed it to where it was before. so i wait for my dad to get off and call him over to watch me do this and verify im not messing it up. i pull everything apart again, take a good look, and set about putting it back together. this time when i try to set it to tdc on cyl 1, i look to double check on the crank pulley and notice that no matter how many times i turn the damn thing, i cant get the tdc mark to line up with tdc on the cylinder by looking at the cams and the dist. wtf?!?!
i came in to post all this frantic **** up here, call it a day and push it onto the street so the tow truck can get it and take it to the shop. hes got it open right now and the only thing he has said so far is "guide(S)?"
he thinks i was only supposed to remove the upper guide and not the second guide, although i have it from several sources that both guides were included in the tsb and they have been running with them off for quite some time. thats a big dif. from what my car is doing (nothin) and at this point i figure im going to be out of a lot of cash to get this fixed. i went over the procedure with the fsm and my dad and brother like four times and it seems like i did everything right...
on the bright side this might be the excuse i need to put on that ported head in my friend's garage...
