dickie »
https://forums.nicoclub.com/dickie-u32299.html
Sun Nov 11, 2007 8:16 am
which guides did you remove? if your chain was slack enough to hit the top guide, removing that and the side guide could have cause the chain to jump timing, although this is very unlikely.
the reason why i advocate NOT removing the guides, but instead replacing the system is because i have had several Nissan techs tell me personally that its not worth messing something up.
also, i noticed some misinformation floating around this site pertaining to which guides need to be removed; according to the dealership tech and an independent mechanic i know who has worked on Nissans/Datsuns for over 30 years, the very topmost guide is the only one you'd want to remove anyways.
some guys claim they have been running without the upper guides for a while, but maybe their tensioner and chains are in better condition and its only a matter of time for them. you willing to take that risk? having your valves bent can easily cost you over $1,000 in repair work, whereas a timing kit is a fraction of that cost...
also, im moving this to the KA section.
