WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Tue Aug 07, 2007 2:02 am
Just make sure to pinch the big vacuum line going to the IACV. Or just pull it off and plug the end with your thumb. The car should die right away.
On almost any car, if you loosen the cables, the idle will drop some. Obviously the correct method is the IACV screw, but in todays world I''m a big fan of whatever it takes.
Make sure your TPS settings are now not messed up since you may have effected the low throttle signal by adjusting the throttle itself and not the in coming air. Thats the big issue with not using the IACV.
WD
