jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Thu Nov 10, 2005 2:45 pm
definitely a ground wire grounding itself out. until i could find some schematics for you, start where u plug in the fuse and trace the wire in there throughout the entire car. if you have a voltmeter, you could also test to see where u are getting current flowing. if power stops flowing in the same area when you test all three systems, then the short is isolated to that area. for each picture i will describe what you do to test for shorts. u will need a multimeter to do this okay (i hope you know how to read this chart)?
VOLTAGE CHECK TEST
1. Remove blown fuse and disconnected all loads (i.e. SW1 open, relay disconnected and sensor disconnected) powered through the fuse. 2. turn the ignition key to the ON or START position and verify battery voltage at the B+ side of the fuse terminal (one lead on the B+ terminal side of the fuse block and on lead on a good ground.)3.With SW1 open and the DMM leads across both fuse terminals check for voltage. IF YES, short is between fuse block and SW1 (point A) IF NO, short is further down the circuit than SW1.4. With SW1 closed, relay and sensor disconnected and the DMM leads across both fuse terminals, check for voltage. IF YES, short is between SW1 and the relay (point B). IF NO, short is further down the circuit than the relay.5. With SW1 closed, relay contacts jumped with fused jumper wire, check for voltage. IF YES, short is down the circuit of the relay or between the relay and the disconnected sensor (Point C). IF NO, retrace steps and check power to fuse block.
*** ALL OF THESE STEPS ARE FOR TAIL LIGHTS, INSTRUMENT CLUSTER, and SIGNAL LIGHTS, meaning all the steps for testing each point in each picture is identical!***
TAIL LIGHTS
CLUSTER LIGHTS
SIGNAL LIGHTS
if you dont have a voltmeter, you'll just have to trace the wires inch for inch and see where they meet and hopefully you'll find itself grounding out. happy hunting!
