Help! The headlights are draining the battery.
JMPitt820
Car: 1994 Mazda Miata C Package
I got into an accident this weekend and now my passenger headight keeps trying to close. This drained my old battery so I went and bought a new one today. I want to stop the headlight from moving so I took out the fuses, but that didn't work. If I disconnect the ground, will that stop it?I searched and couldn't find an answer for this.Thanks.
bangstanger
Car: 91 240SX Hatch
Well on my friends firebird we just disconnected the plug for the motor. I am not sure if its the same on the 240sx. If you need I can go check and see if I can find out where or how for ya. It should be just to the right of the light and maybe towards the bottom of the motor.
onosqv
Car: '92 240sx Vert
like bangstanger said, just disconnect the plug (it's hooked into the frame via a plastic clip) follow the motor wire to the plug. Should be about halfway between horn and bottom of radiator.
Also, if you need a new passenger headlight, I gots 1 - email me if you need it hyphendesignsATyahooDOTcom
