Help! Tach isn't working correctly!
fuzion
Car: Cars.. Web/graphic design.. Yuppp
Ok, I had indiglo gauges installed, everything was workin' fine.
Got my new reverse indiglo gauges last night, installed them, put it back together.. test drive yields the following results:
Fuel: FineSpeedo: Showing 10MPH when the car is at a stopTach: Showing 0 rpm when the car is at a stopTemp: Rises above the normal mark.. almost to the top
So this morning I took it back apart, checked everything, and now ive got the following
Fuel: FineSpeedo: Seems to be ok, haven't driven it yet but its staying @ 0 when the car is parkedTach: Still show it idling at about 200rpm.. Temp: Looks to be normal again
So my question is about the tach.. how do I reset it? Normally the car idles about 900 rpm.. I don't know what to do.. any ideas??
Thanks! :)
quiksilvia
Car: 95 s14 se
did u hit the needle during the install?
fuzion
Yeah im pretty sure I did.. I mean I dont think I punched it or anything but I definitely was moving it around in order to get the gauge over the 200 foot long device for changing the time.. ;)
quiksilvia
Car: 95 s14 se
well thats the problem then, see if you can move it back to where it should be, or buy a new cluster
fuzion
the needle moves fine.. it just sits @ 200 when idling
nothing sticks at all
