Help!!!
K240
Car: 1993 240sx
My car has been overheating. It also has been very slow, since i got it. I replaced the Radiator, Water pump, thermostat, and I added FLEX A LITE fans....It is still overheating. Do i need a fan shroud?i dont have one.... It has been going through some coolant...But i havent found a leak...So im guessing the coolant is going into the engine, So im thinking its the headgasket.....=[ so i took my car in to my mechanic, it has some bubbles in the coolant. He took the head off of it, and it is warped. 850$ for a new headgasket/resurfaced head/ new valves............My question is, Does this have anything to do w/ my power loss? I lost to an automatic EXPEDITiON for petes sake.....I also barely beat a civic...Is the blown headgasket the reason for the HUGE loss of power?
hotshot240sx
Car: my 240sx
yes...a blown head gasket causes massive power loss!
hotshot240sx
Car: my 240sx
and yes a fan shroud is needed!
K240
Car: 1993 240sx
but for 300 come on!!!
K240
Car: 1993 240sx
BTW i have a 93' 240sx coupe
hotshot240sx
Car: my 240sx
it plays a roll in the cooling system. may not seem like it, but it helps controll the flow from the fan to the engine, helping with the pull effect. helps keep the air from running wild, even if you have an electric fan! you can find one at a pick and pull for less than 300.
K240
Car: 1993 240sx
i havent found one yet, all of ours have nothing for the 240s...
Altiman94
Car: 1989 Nissan 240SX
U dont need one
K240
Car: 1993 240sx
Im hoping that i dont, cause i dont have 300$ laying around for a piece of plastic, that will probably break, like all of the other ones....
NISTECH
with out a fan shroud your fan does not pull air just through the radiator it also pulls it from the space all around it, by having a fan shroud it makes the fan pull the air only from infront of the radiator. That is why the fan shroud is so close to the fan.
K240
Car: 1993 240sx
Can you have a fan shroud w/ dual flex a lite fans?
K240
Car: 1993 240sx
BUMP!
12er
it helps,but is not really necessary.
