I have a 2009 versa that is the 1.8 with 6 speed. I was jumping a friends truck today and his was so dead it caused mine to shut off. well then mine wouldnt even crank. so i checked all the fuses and fount the rr def both of the fuses were blown as well as the EGI fuse. so i replaced all and after that it will crank but not start so i check them again and the EGI was blown so after a little testing found that the second my ignition is turned on it pops the EGI fuse . this is where i need help im not sure what else to do i found some used ecus online for only 100 bucks but really dont want to put that out till i know thats the prob.
and this is my main trasportaion so i Need it asap .. any advice would be greatly appreciated and Were is the ECU located in the versas
