help
All things Altima Coupe.
Hussain
Car: 08 Altima Coupe 3.5se CVT
so last night I hit the curb with the bottom of my back bumper. It just hit the bottom of the little end cap thing. just a few light scratches. So today I go to my car and I see my back bumper is sticking out. Turns out the little tab that the screw goes into to hold the bumper on broke.
would it be ok to use a washer and JB-weld it to the half broken tab? It would make a new hole for the screw to go through and hold the bumper in place.... but would it last? would the rest of the tab break off?
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
I wouldn't mind trying super glue honestly. It'll bond metal to most plastics. Some five minute epoxy might do the trick as well.
Irvxing
Car: 2011 Altima Coupe 2.5s M/T
This happened to me a few months ago. What i did was i drilled a small hole close to where the tab was and then zip tied it to the car. You couldn't tell my bumper had been snapped off and it sat perfectly.
you have to remove the screw from the car though and insert the zip tie from the new hole made on the bumper to where the screw went into the body.
Hussain
Irvxing wrote:This happened to me a few months ago. What i did was i drilled a small hole close to where the tab was and then zip tied it to the car. You couldn't tell my bumper had been snapped off and it sat perfectly.
zip ties are a good idea... here are the pics
hungs
Car: 10' 2.5s Altima Coupe Red
nothing a little duct tape can't fix :D
AlexN09
Oh yeah I would go to the zip ties for that one! They'll be sturdy
mikethemike
Car: 2010 Altima 2.5s w/ convenience package
Hussain wrote:[
What I would do is get those little plastic thing that slides over the cap and then screw it back, you know what I'm talking about? Or zip tie it, but wouldn't you rather do it in a legit way? Either way, whatever works :)
SEismyG
Car: 2008 Nissan Altima Coupe 3.5se, Fully Loaded
Owwww! Damn you hit that hard! I can buff out those scratches (gotta see how it looks first...) :D but the ziptie idea isn't bad. A meet is due...
el_blacky06
Car: 2007 Nissan Altima Sedan 2.5s 6MT
Diefinitely zip tie. Same thing happeped to my front bumper on the passenger side.
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
buddy of mine used old plastic and a soldering iron to melt a plastic replacement in when his front bumper came apart...
Irvxing
YEP exactly like mine!
Drill a little hole and zip tie them together and BAM!
Good as new.
My front bumper is actually held with a zip tie atm :chuckle:
SanoSuKe
Any updates on this. I dunno how you guys drilled into the bumper there's barely any space there..
Hussain
I ended up just doing my original idea of JB-weld and a washer. It worked perfect. I put the screw back in and it looks like nothing ever happen
AlexN09
Hussain wrote:I ended up just doing my original idea of JB-weld and a washer. It worked perfect. I put the screw back in and it looks like nothing ever happen
Nice, good idea too.
SanoSuKe
Thanks for updating. I ended up taking mine to the body shop and they fixed it for me for $25
