Help
tryitonce
Car: 1994 jdm Nissan President
Does nayone know whcih swap works in a 94 Q45/President. It takes 10 hours to change the valve cover gaskets on the Q..800.00 dollars. I need to swap the motor with something that works better.
qship96
Car: 1996 Infiniti Q45
So you actually think it takes less time/money to purchase and properly install and integrate a totally different engine not designed for the car instead of a simple valve cover resealing of the present engine already in the car? Come on, that is just foolish!
240RB1
Car: 03 Infiniti G35
92 Nissan 300ZX Z32
95 Jeep Grand Cherokee ZJ
its way easier to just man up and replace the gaskets.oh welcome to the club btw :gapteeth:
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Honestly an engine swap is fairly easy even though it may seem quite intimidating (given time, tools, lift, possible plenum lifting, and all the rest) Honestly having done a swap I probably would do another to avoid valve cover replacement(never done valve covers) IF i knew the history of the engine im replacing it with. But sourcing a decent engine thats 15+ years old.... replacing what else needs to be replaced... shipping.... all the other things required in doing so it is NOT worth all of that... So it is probably easier and more cost effective to replace the gaskets considering you know the mess you have. No other engine is going to work better than the one you have unless $$ is not the issue. Where are you located?
On another not are you looking for a Kouki president grille or any other random parts?
:chuckle:
kevindanielk
Car: 1995 Q45 Stock, except for the blues.
With a little reading of the FSM, located on this forum, you can change the valve cover gaskets yourself, in under half your started time and for about 1/8 of your stated price. Luckily, I was able to do mine in 3 hours, for under $20, with the super deal I got on my gaskets :)
