TY ive been meaning to fix the vacuum tube i didnt think it would be that big of a thing ill change it today if im able and do you know anything about timing to help me out? ive heard horror stories about motors with improper timing so im kinda scared to mess with itNfire247 wrote:Have you checked your distributor timing? It looks to me like its wayyy off.
Also that vacuum leak can cause problems with the car starting sometimes. I'd check those two things before trying anything else.
i put in a brand new fuel filter that was one of the first things i swapped out and brand spankin new egk wires and plugs, and im gonna go tackle the vacuum tube todayEnjoiNismo wrote:Thank you for uploading a video, makes it much easier to help with.
I would check your timing.
Change your fuel filter wouldn't hurt.
Vacuum leak could also be the problem
Have you checked the spark plugs?
