Innovazn »
https://forums.nicoclub.com/innovazn-u151981.html
Thu Mar 31, 2011 6:14 pm
you have 3 options,
1 the route i went and not really suggested is running straight down and along the frame and back up under the spare through a plastic grommet in that tool tray in the cargo space.
2 a route some have done but is a little messy, HOLE SAWWWWWWWWWW your way through the fire wall
3, through the fire wall on the driver side, you will see a plate, it can be accessed from inside the vehicle under the footwell. It holds the ecu or something like that and you can let it hang wont really get in the way. Warning, this hole is extremely small and you will want to a, drill the plate or reseal it someway. otherwise, dont pressure wash your engine.... youll soak the inside of your car. Personal experience. my underglow wires run through there.
