HELP!!!!
zfactoryftw
Car: 1992 s13 coupe
1993 s13 vert
1991 mazda b2200
2004 jeep liberty
i need help with engine connectors!!!! i dont know what to do :wtf2:
zfactoryftw
Car: 1992 s13 coupe
1993 s13 vert
1991 mazda b2200
2004 jeep liberty
1991 300zx na 96' engine
vulcanrush
Car: 93 300zx n/a to tt
you probably have to be more specific.
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
^LOL, yea just a little more specific... Like what connectors? What problem are you having (describe in detail)? What have you searched and found that you still don't understand?
Look, we like to help. But just putting up a very broad question will not help us to help you.
Onyxblue
Car: 1990 300zx n/a, 08 Versa SL, 07 Pathfinder SE, 08 Sentra
I want badly to help, but I can't figure out the OP issue. :)
More detals, please.
BigTDogg (MA)
zfactoryftw
Car: 1992 s13 coupe
1993 s13 vert
1991 mazda b2200
2004 jeep liberty
hey guys thanks for the replies i sat on the phone with z1 for about an hour and got it figured out. i guess my only question would be do the injectors fire constant or are they sequential
BigTDogg (MA)
zfactoryftw wrote:hey guys thanks for the replies i sat on the phone with z1 for about an hour and got it figured out. i guess my only question would be do the injectors fire constant or are they sequential
They fire in order of the firing order. Controlled by the PTU and CAS
zfactoryftw
Car: 1992 s13 coupe
1993 s13 vert
1991 mazda b2200
2004 jeep liberty
ok cause i redid the entire harness stripped back all the tape and everything so im trying to figure what color wires go to which injector once i figure that out i am good
BigTDogg (MA)
zfactoryftw wrote:ok cause i redid the entire harness stripped back all the tape and everything so im trying to figure what color wires go to which injector once i figure that out i am good
Why on earth would you do that? At least mark the stuff before you do!
see here to trace your wires
marty1mc
BigTDogg (MA) wrote:Why on earth would you do that? At least mark the stuff before you do!
LOL, newbie mistakes can be quite entertaining. Use the diagrams that BTD showed you and ohm out each wire back to the pin/connector in the ECU. This way, you will have no doubt of the correct repair.
Good luck and post back if you need help.
zfactoryftw
Car: 1992 s13 coupe
1993 s13 vert
1991 mazda b2200
2004 jeep liberty
nothing was connected when the car came
BigTDogg (MA)
zfactoryftw wrote:nothing was connected when the car came
Sounds like you got your self a project Z there. Best of luck.
Just work on your posting skills a little bit, lol. "help with engine connectors" isn't exactly enough info to get any help.
zfactoryftw
Car: 1992 s13 coupe
1993 s13 vert
1991 mazda b2200
2004 jeep liberty
the wiring diagram worked thanks guys!
