Broadfield wrote:I couldn't reply to your PM because you have your "accept PM's from other users" set to off.
You either blew the fuse for the constant power in the S13 fuse box, or the radio was wired incorrectly which in turn blew the fuse in the S13 fuse box. You won't know anything until you check the fuses and/or pull the radio out and cross check all of the wires for proper connection. Did you use a wiring harness that plugged into the factory radio plug? Or did you cut the factory radio plug off and hard wire the new radio harness on?
Toby
