Ok, heres my problem. i have swaped an sr20det redtop into my s13. everything is in place and almost done. but i have a problem. i have spark and the fuel pump seems to turn on. the problem seems to be that my injectors are not spraying when i crank the car. i double, tripple checked my wiring and it seems to be right. (i used heavy throttle's diagram) if i remove the cas and turned it manually, the injectors spray. car turns on when i pour some gas in the TB, then shuts off when its done using it up. any ideas or hints would be greatly appreciated.
this project is starting to frustrate me.
Fixed your title to generate more views - Hijacker
