help!!
fastass
Car: 95 240sx
ok look i have a 92 240 with a ka in it and i have an unusal problem.. i have searched and searched this problem but no one has this similar problem.. ok well i have bleed my cooling system at least 10 times, poured slowly and all.. but im getting massive air bubbles non stop.. it has a new head gasket and all. no t-stat. and it keeps overheating any info?
fastass
Car: 95 240sx
any ideas?
PapaSmurf2k3
Site Admin
Could be any gasket or any hose in your cooling system. Are you leaking anything?
Check the seal around the water pump, the thermostat housing, the heater core hoses, the upper and lower radiator hoses, and the radiator itself. Its also possible that whoever installed the head gasket screwed up, or the gasket was screwed up when they put it in there.
fastass
Car: 95 240sx
i know the head gasket is good i did it following every step from all data and everything.. i know when it started to over heat i heard a hissing sound from one of the heater hoses.. i toghtened and still same thing. plus no smoke and no water in oil.. and for w-pump and t-stat housing perfect..
PapaSmurf2k3
Site Admin
fastass wrote:i heard a hissing sound from one of the heater hoses.. i toghtened and still same thing.
Tightened it and its still hissing... or tightened it and it is no longer hissing but you are still getting bubbles?
