LargeTacticalDrift wrote:I'm seriously ready to take my car to the shooting range. I put a new coil, condensor/resistor, ingnitor chip, dizzy, and checked all of the connectors on the harness along with all of the grounds. THE DAMN THING STILL HAS NO SPARK!!!!! WTF!!!!! I even had the mechanics that rebuilt the motor for me come by and inspect my work and they said everything was a o.k. and that the only problem that could be left was either a loose ground or corroded connector. I've checked it all over and over and over. The only thing I haven't changed is the ecu. Is there Anybody that lives in south Alabama that can come by and help. I'm about to scratch my eyes out. Has anybody ever had this problem before? God. Any feed back will be appreciated.
If you have a distributor, then you dont have an ignitor chip. So that wasnt replaced, checked, or even seen under your hood.
What you should replace however is the main relay inside the pass apron. Do it. do it.
come on do it.
dooooooooo it
