help
240joe23
Car: 240sx ka24det boosted
just got into the 240 scene. i was with hondas for a while... but i picked up a 92 240 ka24det.. with a garret t25 and tuned with emance.. i know basicaly nothing about these and it currently wont start. we had it running fine but i guess my buddy said it had a vaccum leak. the guy before me (a close friend) put a new turbo on and seals and we got it running fine. then the other day he went to start it and wont fire? now i picked it up and its sitting in my driveway. any suggestions as to why it would do that? thanks for any help..
Shabbernigdo
240joe23 wrote:just got into the 240 scene. i was with hondas for a while... but i picked up a 92 240 ka24det.. with a garret t25 and tuned with emance.. i know basicaly nothing about these and it currently wont start. we had it running fine but i guess my buddy said it had a vaccum leak. the guy before me (a close friend) put a new turbo on and seals and we got it running fine. then the other day he went to start it and wont fire? now i picked it up and its sitting in my driveway. any suggestions as to why it would do that? thanks for any help..
lots of different reasons
240joe23
the battery and starter are fine.. it cranks over.. it sometimes will pop over like it wants to?
240sxFTW
Car: 89, 240sx coupe
I NEED SOME BAODY!!!
sorry i just had a bad day at work so thats how i unwind. ANYhoosers. Do you have spark? Do you have Fuel? and do you have air. answer those questions then come back to us.
Edit** double check the battery- sounds like its not completely dead but it still has some juice (i had the same problem with mi carro.
Klits562
Car: white s13 coupe
check your ignition timingmine did this popping thing you talk about when my timing was off.and look for any vac leaks
240joe23
yea it has spark.. after cranking it over for a while i can smell fuel.. air not sure? their is some vaccum pressure when starting it.. and when i go to start it i put it on the battery charger anyway so its not that..
baron_harkkonen
Car: 1993 Nissan 240SX, 2005 Honda Civic
Klits562 wrote:check your ignition timingmine did this popping thing you talk about when my timing was off.and look for any vac leaks
Yeah, I'd start lookin there. Poppin usually means a detonation, or backfire. Neither one is good for the engine, especially if its a turbo.
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
check your timing most definitely.. Poping is not good.
240joe23
it doesnt pop, it kinda like turns over.. but where do you check your timing on these
baron_harkkonen
Well, you need timing light a piece of soapstone, and a buddy. On the harmonic balancer, there is a notch in it. Mark it with the soapstone, now get the timing light connect the clamps to the battery, and put clamp te inducer wire on spark plug wire #1. Get a buddy to turn over ignition, point the light at the harmonic balancer and see if the light flashes, when the white mark lines up with the timing mark on the timing cover.
240joe23
mmmmmmmm
trackslut240
if u smell fuel, its possible ur plugs are fouled. u will see spark when you plug out the plugs and leave them connected on your valve cover.(ground them to the valve cover bolts). i had this issue and changing the plugs to bosch platinums to start it worked fine for me. i have been running those for a week, now i will throw on some ngk coppers and see how it runs. change the oil too coz u dont want that fuel enriched oil circulating in the car. throw in some cheap oil in there to get it running and soak that fuel out. once it starts, time it and then change oil again before driving. there is an excellent article here about timing, just search for ignition timing ka24de. i used it and was dead on. good luck
kouki_hmongster
Car: Want 97 kouki
A mod list can be very helpful!
Do you have fuel pressure readings? make sure u can get a hold of something to check the fuel pressure. There are possibilities of the engine flooding due to stuck open injectors, bad Fuel pressure regulator, or lack of fuel due to fuell line leakage...etc....and yes change your oil right away, dont want ur bearing to get f** up. If you already had the car running good before then its probably fuel problem. what were your AFR at?
