HELP
hopperwsurf
Car: 1999 infiniti
new to this forums and Nissans in general. Sorry born and raised Ford dude!I have a problem with my 1999 infinity i30. when ever i start the car it starts right away and the stalls. I need to feather the gas peddle to keep it running.sometimes it loops for a couple seconds then sits nice at idle. whenever it is really cold, it starts, almosts stalls then sits at idle.it there and idle air valve or something on these cars that needs to be cleaned.
I could really use the helpcheers
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Try cleaning your throttle body and idle air control valve. Idontknow how savy you are about cars but it could just be a stoppedup air filter.
hopperwsurf
Car: 1999 infiniti
I know my way around fairly well. just new to the Nissan line of cars. rebuilt lots of domestic cars.I will try cleaning out the aformentioned items
NutriaforBreakfast
Well you are the guy to ask then
My buddy and I are going to try to put in a piston and rings inone cylinder on a Ford Escort 1999 for a friend. We are notremoving the engine. New cylinder head gasket has alreadybeen installed. We have the tools for the job includingthe micrometers need to measure hole size etc. We are justgoing to spec it out first, then hone out the cylinder, and thenspec again. If out of spec we are just going to replace it andthen sell the car. No plans to pull the engine.
Any suggestions?
hopperwsurf
Car: 1999 infiniti
should be alright to come from the bottom if that is the plan. Keep lots of cutting fluid moveing when honeing. I would not install the head gasket and head until the piston is replaced.
