green240sxkj »
https://forums.nicoclub.com/green240sxkj-u125259.html
Sun Jan 25, 2009 4:12 pm
mods are as followed
1993 Nissan 240SX Coupe (S13) SE
with 66,xxx Miles
Color: Juniper Green Metallic
Key Features:•Garage Kept•Low Mileage•iPod/MP3 Player Ready (Auxiliary Port)•5000K HID•CLEAN – Overall No Rust! Look at the Pictures!•5 Speed Manual Stick Shift•Pop-Up Moon Roof•Rear Wheel Drive•Never been in an Accident!
Almost 4K of aftermarket and upgraded parts!
Here is what has been upgraded/replaced/modified:
Engine:
(4) NGK Premium Racing Iridium IX Spark Plugs w/Anti-Seize AppliedNGK Racing NX94 Spark Plug WiresUpgraded Larger Fuel Filter (From Ford 5.0L Mustang) (New)Brand New Oil Pan Plug with new GasketCap and Rotor (New)Radiator (New)Removed Fan ShroudRemoved Coal Emissions Can and Vacuum HosesAEM Short Ram Air Intake (Polished Aluminum)Custom Intake Galvanized AEM Intake BracketBattery and Ports RefurbishmentFuel Injector Cleaner (100G)NISMO Aluminum Oil Cap andNISMO 1.38 (Pressure) Aluminum Radiator CapRefurbished Valve Cam Cover and primed and Painted Metallic SilverNew Valve Cover and Spark Plug GasketsNew Water PumpRefurbished (Sand Blasted) Hose/Thermostat Engine Aluminum ElbowNISMO Racing Thermostat (Opens at 160 Degrees vs. Stock 195)Cleaned “Cooling System” Hoses and Installed New ClampsRefurbished (Sand Blasted), Primed and Painted all PulleysPainted Coolant Overflow Tank Metallic Silver
Body:
Refurbished Hood Rod (Metallic Silver)Sand Blasted and Painted Radiator Brackets High Heat Silver (New Screws)Engine Bay Frame Refurbishment and Modification (Black/Green/Silver Color Combo)Metallic Silver Suspension BoltsWipers Studs Painted (Flat Black)New Duralast Wipers with new Rubber insertFront stability Sway BarRear stability Sway BarRing around Sunroof Sanded and RepaintedCalipers Painted - SilverDropZone Racing Lowering Suspension 1.8 Drop Front and Rear (Sandblasted Upper Suspension Components)Projector Headlights with Clear Sealed Beam Lens5000K HID HeadlightsHeadlight Retainer Shrouds Primed and Painted Flat BlackNew Clear/Red Taillights“Sleepy Eye” Custom Flip Up Adjustable Headlight ModificationTrunk Tire Well – Sanded, Protected by Sealing Rubber Coating Spray to Protect from rust. (2 Coats)
Other:Flip Out VW, MERCEDES KeyRemoved Spare Tire Wood Cover and Trunk Carpet (Reduced Weight)Removed Rear Antenna Motor (Reduced Weight)Stripped all Trunk Walls and CarpetDe-Bagged 240SX Emblems
Exhaust:
Full Strait Through Exhaust with 2 3/4in diameter pipes from headers to Magnaflow ExhaustRacing Stainless Steel Headers 4-2-1 Set UpEGR Valve Pipes Removed and PluggedTest Pipe (3” Diameter)
Interior:
New BILLIOT Pure Polished Aluminum Shift KnobNew Leather Shift Boot with Red Stitching“Rebuilt” and cleaned center console and head unit compartmentSanded and Repainted Dashboard and Center Console Framing (Around A/C, Head unit, Shifter, Cig. Lighter, E-Brake, ECT)New Kenwood Head unit with Bluetooth, HD Ready, Sat. Radio Ready, Aux Port for MP3 or iPod/iPhone and LED Blue DisplayNew 2 Pioneer Speakers in front, tweeter and high range Combined2 Diamond Audio Mid-Range Rear SpeakersRear Speaker Covers refinished to Silver (Not installed on vehicle due to custom Swede Platform)Aluminum and Carbon Fiber E-Brake with custom bootFront Speaker Covers Refurbished to SilverRear window platform covered in Black Swede
