HELP!!
Nissan 350z / Nissan 370z general community discussion forum
z33nismo12
Car: Blue z33
My window is stuck a quarter of the way down... I tried everything, slamming the door, while holding up on the switch. I need idea's cause its going to rain tonight... **** my life.
dasoupdude
Car: 2005 Nissan 350Z
when in doubt pull the window up by hand while holding up on the switch..i mean heck if its gunna rain...
z33nismo12
Car: Blue z33
it wont even do that.. its jammed or something..
dasoupdude
did you try taking the door panel off and seeing what is keeping it from elevating
z33nismo12
Car: Blue z33
Ya. Say if the motor is dunzo. what should i do for the time being, untill i get it replaced. is there a trick or procedure i need to do to get it up without the motor??
dasoupdude
Well until you get a motor, there's really not much you can do. I've experienced this problem many times before on a 3000gt and si Civic but never a Z, to get the window up we just pulled up with our hands until it couldn't go on any higher, and we had to use something to stick in the weather strip so it would keep the window from randomly falling down.
carbon z
Car: 2003 Nissan 350Z Touring
1995 300ZX N/A
I can't tell you the fix, but I do know that the last 1/4 in has to do with the door jam switch. If you've noticed. with the windows up, when you open a door the window drops 1/4 in and when you shut the door the window goes up. Check to see if your dome light is working. If not, you may have a blown fuse. Just a thought.
z33nismo12
Car: Blue z33
my
carbon z wrote:I can't tell you the fix, but I do know that the last 1/4 in has to do with the door jam switch. If you've noticed. with the windows up, when you open a door the window drops 1/4 in and when you shut the door the window goes up. Check to see if your dome light is working. If not, you may have a blown fuse. Just a thought.
s
my dome light doesnt work and hasnt since i got the car. i checked the fuses for that and they were fine. Is there a separate fuse for the door switch????
z33nismo12
Car: Blue z33
SO i ended up cutting the window motor cable, and pushed the window up and tied it up.. When i buy a new motor will it come with the cables??
dasoupdude
gikoro23
Car: 91 s13 sr20
take off your plastic door pannel and look at your sheet of metal that has your window rails held held in place. in the middle of the three 10mm bolts holding the window motor there is a plastic piece covering the reset switch (rubber). While the door is closed (and ignition on)1. Raise the glass to the top position.2. While pressing and holding the reset switch, lower the glass tothe bottom position.3. Release the reset switch, and check the reset switch returns tothe original position, and then raise the glass to the top position while having the reset switch released.4. Open the door and see if the glass drops an inch or so.If that dosnt work somthing is in the way of your window or you need to get a new/used window motor and reset it again after instalation.
Burtonboarder950
Car: 2005 350z touring
although embarrassing...garbage bag it for the time being? at least to keep the rain out. My .02
Return to “350z / 370z Discussion”
