Help!!!
240SX=fun4me!
Car: Stuff
alright, I'm scared.
my 1993 Nissan 240 decided that it didn't like me today and doesn't work right anymore. This morning i took the left front fender and sheet metal off to repair some damages left by the previous owner's driving. I put the whole car back together afterwards, *mind you that i never touched anything elctrical during the whole time* and now when my car starts *which it barely does* if i hit the accelerator at all, it dies instead of accelerates. if i hold the accelerator down it just dies! it also dies if I start it and let it idle, but it dies slower then.
Now i drove this car just last night, and it didn't even HINT that it had a problem of any sort.
Now the only other thing that i did, was that i disconnected the battery from the car for about 8 hours while working on it. The only thing i could think of is that my computer either A. died or B. needs to be reset or let to reset itself after being hooked back up to battery?
PLEASE help me out, I'm hoping this is just a goof on me, but I need hel figuring out why the engine upped and decided not to run for me.
Thanx alot.
P.S> the only other thing is that I have no gas in it, and maybe the fuel pump crapped or something?*
trpower7
Make sure your MAFS is still connected correctly. Make sure the battery is connected properly. Make sure you have gas in it. If not, put gas in it. come back after you do these things.
240SX=fun4me!
Car: Stuff
Mafs= mass air flow sensor?
240SX=fun4me!
Car: Stuff
got it fixed, thanx man Went out this morning and played around with wires in and around the air flow area of the car, and then she started no prob.
then of course I had to go out and burn the rest of the winter tires off the back.....;)
