Return to your favorite service writer at the dealer and have them print out the Infiniti dealers perforemd service history. They owe you that.jarred15801 wrote:as far as maintenance history i don't know? i just bought the car last week from a dealer. it's a 97 with 99k miles.
According to BG 44k, you don't have to change out the fuel filter because it "suppose" to clean the fuel filter also.maxnix wrote:Any maintenance history on fuel or intake system? If not, run some ISO-Heet and BG44K after cahnging out fuel filter and air filter before doing the above.
Modified by maxnix at 10:24 AM 4/14/2008
Exactly how is BG44k suppose to disolve all the particles of metal, rust ,sand, dirt, etc trapped in your fuel filter? IT CANTNightRiderQ45 wrote:
It wasn't an infiniti dealer though. He only had the car on his lot for a couple weeks.maxnix wrote:Return to your favorite service writer at the dealer and have them print out the Infiniti dealers perforemd service history. They owe you that.
No car is maintenance free. There are only degrees of maintenance between abused and as new OEM.NightRiderQ45 wrote:God, I'm blessed that my Y33 has been maintenance/problem free. There was a great owner before me and I'm still continuing the trait... Maxnix, what exactly does ISO-Heet do? It gets the water out of your fuel lines correct? Wally World has a 6-pack of ISO-Heet for $3 .
Is this a fluid that you add everytime you fill up?
Then register your car with Infiniti Customer service and they will dictate the dealer service records to you. Wise owners never buy a car without reviewing these first. Helps point to where the Tech may want to look a little more deeply.jarred15801 wrote:
If you believe that, then you haven't read Q45tech's recent fuel injector posts. He uses BG44K more frequently than a priest uses wine. He had a nice goo from recently introduced ethanol.NightRiderQ45 wrote:
One of our prime sponsors if you will look at the NICO Sponsors on the right of your screen.jarred15801 wrote:And what is a site that i can get the knock sensors and wiring harness from?
Well i do know that the car was regularly maintained up to 70,000 miles with the warranty. From 70,000 to 99,000 i couldn't find any paperwork on it in the car. But thanks i will look into that.maxnix wrote:Then register your car with Infiniti Customer service and they will dictate the dealer service records to you. Wise owners never buy a car without reviewing these first. Helps point to where the Tech may want to look a little more deeply.
Every owner needs to have a relationship with a writer or service manager at the dealer.
A Nissan tech told me almost anything will also set a KS code, so they fix everything else first, erase teh codes and monitor it.jarred15801 wrote:couldn't the misfire have caused the engine to knock?
