evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Dec 26, 2007 7:59 pm
what is your gaol? the SC is easier as it requires no exhaust work, but tends to run lower boost, it doesn't help taht it takes more power to run them, but for quick easy cheap (at least cheaper than turbo) it can be very rewarding, turbo is basically limitless in potential power but if you want big numbers you gotta be willing to spend the money, the stock motors can only take so much, but the turbo kits tend to cost more, generate more heat, way more involved instalations, but more flexible and more power potential
