help
idriftnsj
Car: 90s13
i just took my gauge cluster out to put new faces i it and when i plugged the 3 plugs in the back .back in nothing works tach,clock lights nothing
sleepyS14
Car: 1997 Nissan 240SX 2JZ30DETT
2006 SAAB 9-2X AERO
plugs upside down? bad ground? check dash fuses maybe you shorted it somehow. sounds like fuse or bad connection. did you disconnect your battery before you did this? is the car on and nothing works? maybe you're just not getting power. battery dead? based on the info thats all i got for you right now. maybe take pix of the front and back of the cluster.. maybe we can help better
gl
idriftnsj
Car: 90s13
i did forget 2 unplug the batt but the car is on and nothing works
sleepyS14
2006 SAAB 9-2X AERO
check your fuses in the fuse panel under the drivers side left kick panel.. should be one for instruments or dash ..etc
idriftnsj
Car: 90s13
allright now when i start my car up it idles funny and my cluster lights blink at me when i turn my lights on but the only things workin are the temp gage and gas gage
