Zero260 »
https://forums.nicoclub.com/zero260-u34180.html
Fri Jul 27, 2007 2:30 pm
no, how do you have your vacuum line running to your wastegate? is it a small line or a decent sized one, because if you use a real small line it'll boost creep. Also, if you have don't have the factory O2 houseing or downpipe, you can boost a little higher cause of exhaust velocity.
