Couple more quick questions i dont feel like researching(i searched for a bit but) i dont know if they been asked
I was checking out all my oil feed fittings and i got the .63 restrictor can i put it anywhere in the line?? Can i bolt it to my oil filter sandwich then continue my an3 line ..... I didnt know if it had to be right before the turbo i wouldnt think it would matter but eh lemme know.
i know this is gonna start some flamming but can i run dual stock 240sx pumps. Read that a stocker pump flows 80-90LPH so if i ran two in parallel of course that be a GHETTO walbro. My buddy has one he'll give me and im out of $ for the walbro.
Possible problems- i guess pumps draw 4-9amps normally 2 is gonna double that #
Or my buddy has a 1987 NA rx7 fuel pump walbro 255 that i can get and try to make it work? more research.....
Im using an fmu just to get up and running! Im trying to do it halfway right reading a couple blown motor threads.
===On a side note i did a bunch of reading about fmu and fuel pump facts/theory. I keep reading that between 6:1 and 8:1 work for 240sx and pending carbon deposits and system condition this normally holds up fine. What about the factory 1:1 factory regulator does that mean fuel pressure is actually ex= 7psi stock fuel pressure 40---full boost 7x8+7!!!!!! so it be 103 NOT 96 like i always read ----just a thought
i read about a few dual walbro set ups and even a walbro on a NA ka24 . Installing a bigger fuel pump raises the "volume of fuel going thru the system. In other words 80lph to a 255 is almost triple the amount of fuel. I even came across a couple pump failiers due to running below 1/4 tank of fuel and the pump overheating from the increased flow. (tons of fuel pumping not much getting used fuel used to cool pump) I then looked into running a micro switch and series external pump coming off the intank and that seems like a bad idea didnt read into very much.
figured i try and get some group thoughts just alot of "sketchy" information out there*
