help!!
240love
Car: 240
hi...my question is...on a rb20 do the injector plugs split up like separate..because i was looking at my harneess and i cant find two of them
Carl H
there is an injector subharness on the rb20, its for the aac valve and injectors 4-6.injectors 1-3 are on the main harness.
240love
Car: 240
awsome...thanks
240love
Car: 240
ok i got a question...on the rb20..where the hell do you plug these up at?
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
First pic are the two relays, for the fuel pump etc. Second one is body harness plugs, i've never done RB20 on s13, just S14 do i dont know, and the third is part of the Ignition harness area, there should be a plug for it and it will mount on the drivers side behind the motor. At least thats how we have on my friends motor, im probably wrong, someone correct me. Its been awhile since i've messed with RB20 harness ****.
240love
Car: 240
thanks alot....any more outputs?
Carl H
toss the metal twinkie in the trash its a redundant part now.put green or blue relays in the green plugs, those are for the coils and the eccs.as for wiring the others, well that i cant tell you...but tracing will tell you what needs to be done.
Kansei240sx
What the hell is that metal twinkie anyways?
Carl H
its part of a system that is no longer connected...the fuel pump voltage control module.basicaly keeps the fuel pump quiet by underrunnining it by varying the voltage...but the s chassis doesnt have the circutry for it and the metal twinkie is a balast resistor for the system.so to recap the proper way to install the metal twinkie is to install it in the trash.
240love
Car: 240
lol...thanks alot
240love
Car: 240
ok guys..i need help again!!!!....ok so everything is hooked up..car cranks but i dont get any spark...ahh this is so frustating
Suicide.Veteran
Car: 93 Nissan 240sx
check that little ground on the harness near the ignitor chip.
240love
Car: 240
yeah its grounded....my friend said there was something wrong with my harness and that he would probably have to redo it...but i dont have the time and money...any more suggestions?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Oh..... I always thought that was the resistor pack for the injectors.....
gawdzilla
Car: none
Sil240 wrote:Oh..... I always thought that was the resistor pack for the injectors.....
resistor pack looks like that, but only the 26 should have them from the factory. it also has i think a 8-wire connector (7 wires used).
240love
Car: 240
its alive!!!
DJButton
Car: 2010 Nissan 240sx
Grats! so is mine, just not very well...
240love
Car: 240
yeah mines ok but one injector isnt shotting fuel i think so im on five cylinders right now..i really hope its the injector and not the motor
